Wrench Light
Ok this is driving me crazy, my Wrench light seems to be coming on for no reason. I have a 2008 FEH with about 9000 miles. The light will come on sometimes after driving for a few minutes and stay on for the duration of the drive. When I turn the ignition off and right back on again the problems goes away. There seems to be nothing wrong with any of the systems. Has any one else had this problem?
Re: Wrench Light
Originally Posted by lukemac1
(Post 165464)
Re: Wrench Light
I had the same problem for about 3 months. I kept going to Auto Zone when light was on..no codes..went there when lights off...no codes. One day about 2 months ago it just stopped coming on. It was coming on so often i was worried, but now it has stopped. i wonder if it was something with the as cap, or fill-up or something. Whatever it is it is gone.
If no codes are thrown at Auto Zone, i would not be too concerned. |
Re: Wrench Light
Originally Posted by Hybrid Labbett
(Post 165518)
Re: Wrench Light
Been happening to me for the couple weeks too. Too busy to get it checked
Re: Wrench Light
Auto Zone and the Scan Gauge only check the OBDII codes and there are MANY more that can turn on the light that dont have anything to do with emissions which is what the OBDII is for.
Re: Wrench Light
I'm having the problem with the Wrench light right now, it's really annoying since I've already took it to the dealer to have it looked at. drove it home it still keeps coming back on. scheduled a appointment, have to take it back in again. I feel that there's something allot more simple to this problem.
2008 Mazda Tribute Hybrid 8900 miles |
Re: Wrench Light
A loose gas cap will set off the Wrench light.
We had a pin hole leak in our gas filler tube that was setting ours off. The dealer replaced the gas cap, filler neck and the plastic tube assembly behind the filler neck to fix it. |
Re: Wrench Light
Try to NOT turn the key off when you take it back. See if the tech can bring the scan tool to your car and check the codes before you turn it off. Also have the gas cap checked you might have a leaky one.(vapor)
Re: Wrench Light
Mine quit doing it since I changed the oil at about 9100 miles
| All times are GMT -7. The time now is 04:13 AM. |
