Weird ICE/EV behavior today
My FEH was really acting weird today. Temps were between 0-10F and several things were happening that I couldn't explain:
- After being fully warmed up (CHT>210F) the ICE would not stay running even with the defroster ON/"in the red zone'. - HV battery seemed to have lost a lot of charge overnight. SoC was down around 30% this morning after being around 43% when shut off last evening. - Took a long time to charge up HV battery, probably more than 30 minutes of driving. Even when braking the charging current would only go up to maybe 20 amps and then only for a few seconds. I suspect this was because the battery was so cold? - Even when finally charged up fully (>50% SoC) and fully warmed up the ICE was kicking in even when just sitting for a minute at a stoplight. Until this last few days of cold weather the ICE/EV was acting pretty much as expected. I'm just confused :confused: as to why sometimes it doesn't stay EV when it seems it should and then today it wouldn't go ICE when the heater controls were set to defroster. |
Re: Weird ICE/EV behavior today
You answered your question, the hybrid battery is too cold. Monitor this via the TAV reading in your scanguage.
Originally Posted by Billyk
(Post 246074)
Any idea at what hybrid battery temp should I expect normal operation? |
1 Attachment(s)
The hybrid battery pack will function normally at the 75F range. It will go into EV at a much lower temperature than that. If you park the vehicle outdoors in Minnesota during the winter, well, it is going to take a lot of driving to warm the hybrid battery pack up to normal range. If you have a garage, then is there an electrical outlet? If so, then do you have the FORD engine block heater installed--option 41H? If so you have a direct connection to the hybrid battery pack heater which makes life so much easier during the cold winter months.
Attachment 2693 |
Are all the replies in this thread going to apply to ANY model year FEH?
2 Attachment(s)
Originally Posted by RiverRat37
(Post 246106)
NO. Ford discontinued the connection to the hybrid battery pack heater early in the 2008 model year. Attachment 2691 Attachment 2692 |
Go more in depth on this ford battery pack heater..I have a 05 and an 06 hybrid with no factory black heater installed..how does this work with the hybrid battery connection..I'd like to maybe find one
Originally Posted by cje2310
(Post 246138)
1 Attachment(s)
(Post 246139)
Purchase option 41H (engine block heater) and have it installed. Presto! You now have a hybrid battery heater. There is a "Y" connection under the front windshield washer fluid bottle that connects the wire going to the hybrid battery heater, the wire going to the engine block and the wire going out of your front grille for the household electrical plug.
Next I looked near the windshield washer fluid bottle and found the following plug. Attachment 2689 Is this where I would plug in the wiring harness you showed here: https://www.greenhybrid.com/discuss/...94/index2.html ? Or do I also need the 10B689 - In-Car Battery Charger ? Also are the part numbers shown on that photo the right part numbers for an '05 FEH? |
1 Attachment(s)
This is option 41H:
Attachment 2688 The Y connector is mounted to the side firewall in the engine compartment--under the window washer fluid bottle. I can't tell from the photo if your item in the photo comes off the firewall but the white threaded piece appears to have been bolted into the firewall or something similiar. I don't have enough information. I'm see if I can obtain a photo or something from the workshop manual. |
