Troubling Noise from Under Hood
Maybe I just never noticed it before, but I think I'm hearing a new noise.
I was sitting in the garage, in the FEH with doors closed and key ON (ICE off and cold) to program the SGII. I could distinctly hear a whining or humming noise from the engine area. I got out, raised the hood, and the sound is coming from somewhere around the ICE, possibly to the rear. When I turn the key OFF, the whining stops immediately, nothing spins down like a pump might. No codes on the SG and no dash warnings. Seems to drive normally. Am I being paranoid or is something going on? MECS pump getting noisier perhaps? |
Re: Troubling Noise from Under Hood
Originally Posted by econoline
(Post 224529)
I was sitting in the garage, in the FEH with doors closed and key ON (ICE off and cold) to program the SGII. I could distinctly hear a whining or humming noise from the engine area. I got out, raised the hood, and the sound is coming from somewhere around the ICE, possibly to the rear. When I turn the key OFF, the whining stops immediately, nothing spins down like a pump might. No codes on the SG and no dash warnings. Seems to drive normally. Am I being paranoid or is something going on? MECS pump getting noisier perhaps? GaryG |
Thanks Gary, I just saw your post at Hybridcars.com. But I'm still unclear on how you check the MECS pump. Is a good pump silent, or should a good pump make some noise with the key ON? I guess what I'm asking is does a MECS pump fail by ceasing to run or does it get noisy first? BTW, my FEH just turned 30k miles.
(Post 224533)
If I were you I'd relax about the noise now that you know how to check it for running or not. The noise could just be caused by something else from the vibration of the pump. It could also be the power steering pump if the wheel is in a certain position. If the noise starts getting louder than that may be of concern so keep us posted. GaryG |
