Troubleshooting Rear Window Defroster?
So I tried the rear window defroster for the very first time and it doesn't work. The little LED doesn't illuminate and the grid doesn't warm up.
I have vol 1 & 2 of the shop manuals but no electrical diagrams, plus the owner's manual. I did as much troubleshooting as I could but got nowhere. I'd appreciate any suggestions if anyone else has been through this. Here's what I checked so far:
Thanks for any help with this. I'll probably never need to use the rear defroster again, but it bugs me to know that it's not working, so I'm determined to fix it. |
Re: Troubleshooting Rear Window Defroster?
The relay is in the battery fuse/relay box in the engine compartment. You could check if you have voltage at the fuse also.
Originally Posted by wptski
(Post 234451)
I don't think this relay is in the BJB. There are 7 relays and 32 fuses in the BJB, but none of the relays are related to the defroster function. The relays are:
Good tip about checking voltage at the fuse. I found the FEH wiring diagrams on eBay for $5, so that is on the way and might help with this. |
Originally Posted by econoline
(Post 234455)
Bill,
Good tip about checking voltage at the fuse. I found the FEH wiring diagrams on eBay for $5, so that is on the way and might help with this. GaryG |
1 Attachment(s)
(Post 234455)
Bill,
Good tip about checking voltage at the fuse. I found the FEH wiring diagrams on eBay for $5, so that is on the way and might help with this. Yes, the relay is in the SJB! Yes, the diagram needs some darkening and contrast for sure. Well, I tried... Okay, that's much better. :) Attachment 2920 |
Bill, thanks! That's a very useful diagram and I can do some voltage checking from there. My guess is the problem will be in the SJB and I really don't want to try removing that.
Gary, thanks for the tip on rebooting, and I'll give that a try. Will I lose any configuration data if I reboot? [Nevermind, found the answer in the owner's manual in the section about replacing the battery] |
(Post 234465)
Gary, thanks for the tip on rebooting, and I'll give that a try. Will I lose any configuration data if I reboot? |
