tire pressure monitor questions
I have a 2008 FEH and this year I am planning to buy some winter tires and rims. As I understand it, the tire pressure monitor is somehow part of the valve stem, so I would have to install them on the new tires and they're not exactly cheap.
I was wondering exactly what would happen if I just simply didn't have them? Obviously the tire pressure monitor wouldn't function, but is there any negative to that? Also, I presume the dash indicator is probably going to light up. Is it just a solid light which I can easily ignore, or is it more intrusive (blinking and beeping)? |
Re: tire pressure monitor questions
Originally Posted by Transient
(Post 211745)
I was wondering exactly what would happen if I just simply didn't have them? Obviously the tire pressure monitor wouldn't function, but is there any negative to that? Also, I presume the dash indicator is probably going to light up. Is it just a solid light which I can easily ignore, or is it more intrusive (blinking and beeping)? Why not just get new stems? |
Mine went off last week...solid light in the dash and the info center said "low tire pressure"...no idea about the valve stems though.
Originally Posted by Slick
(Post 212158)
yeah right away and it was right, slow leaker drivers rear, under 30 psi I'm thinking set it off? Been a few days now, meant to check it again and keep forgetting...hasn't gone off again yet but need to use a gauge on it...
| All times are GMT -7. The time now is 04:09 AM. |
