Electric Vehicle Forums
-   -   Are there any lowering kits available for the 2008 + FEH? (https://electricvehicleforums.com/forums/ford-escape-hybrid-26/there-any-lowering-kits-available-2008-feh-20475/)
exbauer Dec 5, 2008 11:13 PM
I am thinking about lowering my 2009 FEH and wanted to see if there is anything out there. I looked on Tire Rack and they offer H&R springs, but only for the V6 model. Has anybody done this and are there products out for the 2008 + FEH?
colchiro Dec 6, 2008 06:48 AM
Re: Are there any lowering kits available for the 2008 + FEH?
Back in the olden days, they'd cut a bit off the springs to make them shorter, but that also had the effect of stiffening the ride (which we don't need with 45 psi in the tires).
ronsfastl Dec 6, 2008 06:53 PM
I remembers seeing a online parts by Ford that had set of 4 springs that would lower it app 3/4'.
Found this with a search and I see no reason that they wouldnt work on 08 and 09. You may want to send them a email asking.
H&R Lowering Springs for the Ford Escape 01-07
http://www.autotrucktoys.com/escape/.../hrsprings.jpg
Fitment Guide
YearModelhttp://www.autotrucktoys.com/escape/images/ssarrow.gif2001-2007Escapehttp://www.autotrucktoys.com/escape/images/ssarrow.gif2005-2007Escape Hybrid[B]
Year Model
2001-2007 Escape
2005-2007 Escape Hybrid
Your Price: $279.95
OVERSIZED - OS1
Shipping: $29
http://www.autotrucktoys.com/escape/...ynow_white.gif
Stock CodeAvailabilityHR51601Usually ships in 1 to 2 business days.
Performance Lowering Springs for the Ford Escape When you want to get serious, H&R Sport Springs are the hot setup. These are our most popular springs - they lower your machine 1.6 inches for improved handling, better aerodynamics and a simply outrageous look. Each spring is tuned for that elusive combination of shifter-kart handling and a controlled, yet comfortable ride (about 25-30% stiffer than stock).
colchiro Dec 6, 2008 06:54 PM
I thought the '09 was already lower than previous years?
Billyk Dec 6, 2008 08:14 PM
The 2005-07 models were 70.4 inches high.
The 2008-09 models are 67.9 inches high.
The current style appears less aerodynamically shapped but the lowered height must contributed to a smaller frontal area and thus improved aerodynamics as stated by Ford.
Current Specifications: http://www.fordvehicles.com/suvs/escape/features/specs/
Previous Specifications: http://www.cars.com/go/crp/research....Selection=true
pauli18 Jan 11, 2011 12:46 PM
old thread i know, but has anyone done this to their feh. iv always loved the look on most vehicles especially suv's. i too have seen 3/4" drop using springs for escapes. any updates? i didnt want to start a new thread for an old topic.
D-mac Jan 11, 2011 02:31 PM
One reason that there may not be a lot of options for lowering an Escape is that there are only Koni shocks and strut inserts available (by special order from Holland) that are built to handle higher spring rates than stock. The KYB GR2 shocks currently available are an OEM replacement and not a performance shock.
Slapping these H&R lowering springs on stock struts will likely make for a hobby horse ride in a short time, but maybe people who want to do this wouldn't care anyways.
colchiro Jan 11, 2011 06:31 PM
I find tires at 45-50# make for a stiff enough ride, let alone adding higher spring rates.
pauli18 Jan 11, 2011 07:33 PM
thanks for the info. thats why i ask
