Re: Sudden loss of Power Steering
i think it is good - just not for sure. cleared the codes and it showed no dtc present.
first though i jacked up the front so that the tires were off the ground; then i used forscan. after that i got the laptop and associated stuff (there is a lot with my rigg-up) out of the way and of course the key was off. there is a reset of the ps control module - from the internet but i dont know if it is valid - cant hurt. put the steering wheel straight ahead i had already done that Turn the key to on. The eps indicator comes on for 6 seconds; within 4 seconds while the indicator is On, turn the steering wheel 45 degress to the left and hold it until the eps indicator goes off - well it wont be very long since it is only On for 6 seconds. turned the key off and bought some of the stuff inside. Then i disconnected the negative battery cable for 5 minutes of so (i know one only needs to do it 10 seconds (i think)). reconnected the battery. few minutes later i did the relearn procedure for the 09 which is one of the simpliest ones there is: gently push all the way down on the brake pedal and gently let it come back up. when i did the reset procedure, i noticed that the wrench light was NOT on. i am going to leave it jacked up and when i get back from work tomorrow evening, i am going to start it. If the wrench light is NOT on - it is OK (i hope) |
So you didn't replace the sensor? It'd be great if it keeps working. Let us know and good luck!
at the final of this - SO happy;
took it off the blocks and started it and there was no wrench light; pulled up a little - ps is good. left it idle and drove around the block - Perfect power steering. had i had forscan there may not even have been a post. a FAIL-SAFE system designed by ford engineers (I guess) - if not then it was a fluke and i am SURE it was not that. they have it designed that if you are sliding on ice (or snow) and turn whereby the turning does not result in the corresponding amount of turning, and then go off the ice and it jolts the steering quickly back to where it should be - then the angle sensor comes into play and it recognizes that AND then kicks it off of power steering to save the electric motor gears from being damaged (and thus the FAIL-SAFE system worked). ALL of this is IMHO. cannot believe there would not be a post on this forum that covers this. ALL i did was erase the codes using forscan (i think i have written what all i did (dont want to go out of this and look it up). someone did say to do that on one of the replies to one of Brian youtube videos. |
Originally Posted by fglaustin
(Post 272452)
took it off the blocks and started it and there was no wrench light; pulled up a little - ps is good. left it idle and drove around the block - Perfect power steering. Not bad for a "country boy!" ;) |
(Post 272452)
There is always a lot of programming logic that goes into critical systems like this and because we do not have access to the engineer's thinking and the corresponding logic, we find these things out when they occur. This was like one of those episodes of The Saint. Now go out and find some company and have a martini! |
Originally Posted by AlexK
(Post 272352)
That's the torque sensor code! :( It's very specific. Unless you find something else, and after you check all the connectors. Even though you didn't get the wobble, apparently the PSCM just proceeded to shut down the assist completely. I think your torque sensor went AWOL. I'm sorry. :(. It's really not that terrible a job, it just takes some time and care.
A |
I haven't had the problem but I've bought a sensor as a hedge. I don't intend to collect a lot of spare parts for this car, but I don't care who you are: You're not going far without steering it! Lol.
Hello fglaustin,
a month ago, when doing a U-Turn quicker than I should have, my Power Steering went off. I am guessing it was the same fail-safe system that kicked it, so reseting it would be all I need! I am not sure about the procedure you used. I found the FORScan software but I'm not sure what features I need. If all I need is to reset DTC errors, then the android app would work. But if I need to do "Configuration and Programming", then only the Windows version with Extended License would work. Please share the steps or the link/video you used. I did read through the entire thread but couldn't understand the steps, especially the reset and the 45 degree part :) Thank you https://cimg9.ibsrv.net/gimg/www.gre...be90e601a0.png |
Check the fuse under the hood. Mine was blown.
The flash and escape from the recall would have been negotiated. In the end, this is such a big problem, it saved Ford from huge losses on the Escape program. Not fun for stuck owners but at least they are still selling Escapes.
