A Sticky Idea....Normal/Abnormal FORScan Values
Since we are dealing a lot on this forum with FORScan readings, especially as to the HVTB, I thought it would be useful to have a thread where normal values are listed along those that should be monitored or a are a sign of a failure.
I just rebalanced my HVTB pack and took a look at some other figures. My HVTB's DEL_MOD_V was 0.13 and that took some searching to figure out that was an OK number. In the same vein the software version of my 09's BCM was 2007-11-30. Is there is place to go to determine current software versions? |
Re: A Sticky Idea....Normal/Abnormal FORScan Values
Is there is place to go to determine current software versions? My 09 BCM is: BCM - Battery Control Module Part number: 9M68-10B687-AC Strategy : 9M68-14C197-AC Software version: 2007-11-30 It says there is 1 newer version but then won't update it. The newer one is probably for 10+ |
