Snow Chains
I need snow chains for winter driving in the California mountains. At times, the CHP requires them on all vehicles, even 4wd/awd.
I have looked at chains, cables and Spider Spikes. Does anyone have experience or comments on these devices? My 08 FEH = FWD. |
Re: Snow Chains
There is no substitute for CHAINS, at least for the cross-links. There are some really good quick-n-easy install tire chains out there in the market these days. Just remember REAR chains first provided you have AWD, and slow she goes with chains on. With FWD you have no choice and DEAD SLOW will be the rule of the day.
Re: Snow Chains
I didn't know chains were still legal. They were outlawed here years ago.
Re: Snow Chains
I'm a big fan of these:
http://www.tirechain.com/DIAMONDSTYLECARCHAINS.htm
Originally Posted by wwest
(Post 152746)
The only reason I could come up with is in a funky stop the back end might swing around. But beyond that you should have better control with the chains on the front. So what am I missing? |
Re: Snow Chains
I see two issues here:
Traction to move the vehicle & traction to keep the vehicle on the road. For my front wheel drive, moving the vehicle would place the chains on the front. For keepint the vehicle on the road, I do not know which is best. The problem where I will drive is icy 2 lane mountain roads with hairpin turns and 400' drop offs. I am still thinking front. Has anyone tried cables or Spider Spikes? |
Re: Snow Chains
Originally Posted by DavidH
(Post 152776)
Re: Snow Chains
Originally Posted by queenfan
(Post 152764)
That said, there are some Italian cables that I've seen that are really slick with springs so they auto-tension. You might want to look around! I think you can make installation easy if you get one of the nifty cheap aluminum floor jacks to go along with the chains. |
Re: Snow Chains
I think in the FEH you should ALWAYS put chains on the front.
And probably ONLY the front. The rear is hardly ever used, and when used, is only used intermittantly. I have used "cable" type chains on the front one time, on Interstate 80 through Wyoming. There was not a lot of snow, but there was black ice, and the chains really helped. One time, and only once, the cross wind pushed me sideways onto the grassy snow covered shoulder. ( I was only going 25 miles per hour at the time! ) I figured I would get stuck. But nope! The chains and my little FWD hybrid pulled me right back onto the pavement. I don't think my wheels spun at all. Mary, I don't know what to make of what you say half the time! Chains are REQUIRED in most western states when it snows! You get a ticket for not having them! And in Colorado, I think all vehicles over 10,000 pounds must carry them whether it is snowing or not. ( In the Colorado Rockies, it can, and does snow in summer, at 10,000 feet, and although it usually does not pile up in July, you can have black ice at night in July. ) When you bought your car, everyone should have received a pamphlet from Ford that states "cable type chains only" on the FEH and talked about proper use and installation. Due to low clearance in the wheel wells, real old-fashioned chains are not to be used and may damage your car. If you bought your car in Summer, or in a warm state, this paperwork may have gotten over-looked, but should be a part of every new sale. -John |
Re: Snow Chains
For the record, I spent 30 minutes looking it up, and tire chains ARE ALLOWED in Minnesota.
Perhaps Mary, there is something special about not using them in the city limits where you live in twin cities. But considering how many miles are in RURAL areas.... Tires Chains are not only legal, but REQUIRED in many places of Minnesota! If you would be willing to find out were they are NOT allowed, that would be helpful. Although I also read that "visitors" are not bound by the rules, and I have Colorado Plates and driver's license. :angel: Minnesota Statutes 2007 "169.72 TIRE SURFACE; METAL STUDS." Solid rubber, metal, and studded tires; exceptions; permits. (a) Every solid rubber tire on a vehicle shall have rubber on its entire traction surface at least one inch thick above the edge of the flange of the entire periphery. (b) No person shall operate or move on any highway any motor vehicle, trailer, or semitrailer, having any metal tire in contact with the roadway, except in case of emergency. (c) It shall be permissible to use any of the following on highways: implements of husbandry with tires having protuberances which will not injure the highway, and tire chains of reasonable proportions upon any vehicle when required for safety because of snow, ice, or other conditions tending to cause a vehicle to skid. Subpart (d) is long, but basically states studded tires are not to be used by residents, but are ok for visitors. Subpart (e) states that studded tires are allowed for rural postal delivery carriers. |
