Electric Vehicle Forums
-   -   SJB Smart Junction Box_ Tire Sensor Failed (https://electricvehicleforums.com/forums/ford-escape-hybrid-26/sjb-smart-junction-box_-tire-sensor-failed-29116/)
hc45 Sep 25, 2013 07:00 AM
Hello, i still having the Tire Sensor Fail Sign, i bought the new sensor but still the same..:omg::(
I went to reset the main module, but it does nothing.. the mechanic says is the SJB... does any one had the same issue.. any help please:embarass:
Thank you.
H.
wptski Sep 26, 2013 06:10 AM
Re: SJB Smart Junction Box_ Tire Sensor Failed
Thank you.
H.
That year used the band type TPMS sensor and not the stem type. You had "one" installed and "only" that one won't train?
The train tool is placed 180 deg. from the stem on a band type.
hc45 Sep 26, 2013 03:42 PM
Hello Bill.... The mechanic check it before tell me i had 1 tire bad sensor Band Tipe. So i bought it ( $77.00 ) new... Now, the same issue.. There are all 4 installed... I don't like guessing and spending the money, one day is one thing, the other another thing...
I rally don't know what to think...
H
wptski Sep 27, 2013 03:35 AM
H
I had a TPMS fault on my '09 FE that was covered under warranty and they replaced two of them. There is a battery in them so they don't last forever and probably not as long as they are supposed to!
hc45 Oct 1, 2013 06:29 PM
Hello..
I understand.. But do i have to buy 3 more ?? Uupsss...
Why the computer says is the SJB ... There is'nt a ford engineer around....?/// how could give answers and stop the mechanics guessing ??
Good night...
wptski Oct 2, 2013 04:50 AM
Originally Posted by hc45 (Post 249815)
Hello..
Good night...
I have no idea why your mechanic says it's the SJB. They do have a special TPMS diagnostic device but other simple devices just retrain the sensors. If a sensor doesn't train, it's thought to be bad. You should only need to replace sensors that won't train. If none will train, you have other problems.
Ford engineer here??? Never has been.
bwilliams1188 Oct 15, 2013 06:26 PM
I also had this issue and was told by a dealership the SJB was to blame.
Apparently a low voltage from the battery can trigger electrical issues within the SJB (fry the board) and sounds like the TPMS's and driver's door lock are the first to go. I also had issues with the rear wiper. Had the SJB replaced today and everything works as normal. I did not install new sensors.
Not sure I would trust a mechanic to tell you that unless they had their hands on a diagnostic tool from Ford for your hybrid. Unfortunately a dealership would charge you both arms and a leg to plug up their diagnostics and a little investigation and find out whats up.
el_pablo Oct 26, 2013 09:34 PM
I do have exactly the same problems driver door lock, tpms and rear wiper won't work. How much should I expect to make it repair? Also, can I DIY?
hc45 Nov 24, 2013 04:52 AM
Thanks BW... I think i have these issue... My driver door lock is not working... Also i still have Tire Sensor Fail sign in my dashboard, that really :angry:...
So i will get a new battery----but could you give me the exactly part# of the SJB i will have to buy ? Please... FEH 2006... I will appreciated.
Have a happy sunday.
GatorJ Nov 24, 2013 10:47 AM
Pretty sure it's
6L8Z-15604-FB
http://www.ebay.com/itm/BRAND-NEW-OE...9da395&vxp=mtr
You can email that eBay seller your VIN and they will confirm the correct part number for you.
