Electric Vehicle Forums
-   -   Scanguage coding and fuel pump pulse width (https://electricvehicleforums.com/forums/ford-escape-hybrid-26/scanguage-coding-fuel-pump-pulse-width-22040/)
Billyk Jun 27, 2009 05:49 PM
Has anyone gotten the Fuel Pump Pluse Width coding to work? :confused:
This is for Bank 1
TXD= C410F1221141
RXF= 046205110641
RXD=3010
MTH= 000200010000
coded FP1
Does one have to have Bank 2 coded and in operation for these readings to exist?
wptski Jun 27, 2009 08:03 PM
Re: Scanguage coding and fuel pump pulse width
This is for Bank 1
TXD= C410F1221141
RXF= 046205110641
RXD=3010
MTH= 000200010000
coded FP1
Is there a reason that the TXD is different than what's in the PDF from the SG site listed for FORD CAN?
Oh, I see, you used the FORD PWM! I think that you have to use FORD CAN.
Billyk Jun 28, 2009 11:19 AM
I tried the Ford CAN values without any luck.
I also tried to obtain the air/fuel ratio with these numbers:
TXD: 616af10114
RXF: 044145140000
RXD: 2808
Mth: FFFD00020640 or FFFE0001066B
NAM: A/F
but I was unsuccessful. I obtained the A/F numbers from: www.cleanmpg.com/forums/showthread.php?t=18601
I do not know if the cleanmpg numbers were referring the Ford Escape Hybrid or another vehicle.
Billyk Jun 28, 2009 05:29 PM
1 Attachment(s)
Thank you for the reply. I got the Air Fuel ratio to display as shown below. The injector pulse width coding is still being researched.
Attachment 3161
wptski Jun 28, 2009 08:40 PM
http://i241.photobucket.com/albums/f...atiojune09.jpg
I'd like to see injector pulse width too! I think Bank #1 is $125A and Bank #2 is $125B. I'm not sure if that a Mode $22 or not either.
I know diddly squat about coding the SG-II!:(
Billyk Jun 30, 2009 03:50 PM
1 Attachment(s)
I sent CMD 221141 into the scanguage and received this:
Attachment 3160
I can't do anything more without feedback as I don't know "coding" for the scanguage either.
