ScanGauge Data, Xguage & readings
1 Attachment(s)
So every once in a while I get this idea of why we don't have a thread/stickey with the SC Codes to plug in. And to up it a little what the codes should read, like normal, min, max, and special notes.
I know Carl(?) DD, has an image in the photo section I refer to, and even recently went to SG's site which is updated with most codes, so they can be found relativly easily. But to find them, and know what they should read is 2 differnt things. Personally I'm a good follower, you give me instructuions I can read & do, but a lot of times I may not understand what I'm doing, just the final result. If I know more of what these codes mean I might be able to do better :) I was thinking a xls spead sheet would be easist format. Even better would be a way to post it in open format we could all add our own notes, but not sure how to do that. Something like this attached file: UPDATE: 12/29/08 Small updates, Can't find the FWT code :( DD Is the correct CHT listed? I am also able to save to a htm file for easy viewing, or anyone that can't view an xls file: http://www.geocities.com/bryanw20@sb...t/SGxCodes.htm |
Re: ScanGauge Data, Xguage & readings
Interesting format you created. Maybe this format can be created by this forum administrators for posting in the scanguage thread.
Ideally you'd want the file in an area where people can download, but one person is responsible for corrections and has access to the file for updating. (ie., just one copy exists.)
BTW, no personal info in the file. ;) Good job. |
Yet you need to allow for differences due to a variety of factors: such as ethanol % in the fuel--towing loads--temperature extremes
Originally Posted by Billyk
(Post 193941)
I think I'm up for the task of compiling, and updating the spreadsheet regularly, but I'd definatly need help getting figures. I'm hoping to 'borrow' Desert Dog's, GPSMan,Gary's, etc's work to save some typing at least on the codes. (Sorry I'm bad w/ names) I plan to compile #'s found on this board, plus what anyone wants to add/send in directly. I need to browse cleanmpg.com as well, I havn't gone to that site at all, so if anyone sees a good thread, you can PM it to me, thanks. |
Just a 'bump' to show I updated the data (in the first post)
Also what is 'critical' SOC, if one were to say sit in N with the radio on, 1) will the HV batt protect it self and shut off/revert to 12V battery & 2) when is it to low to start, require a 12V jump? |
This is kind of what I was getting at / looking for with the ScanGauge Data Depository Sticky at the top of this forum.
I've posted what my car, a 2005 does, and Billy has done the same, and so have some other people. If you wish to tabulate into a chart, then fabulous. Feel free to utilize the Sticky we have already started. :D -John |
Originally Posted by gpsman1
(Post 193967)
I've posted what my car, a 2005 does, and Billy has done the same, and so have some other people. If you wish to tabulate into a chart, then fabulous. Feel free to utilize the Sticky we have already started. :D -John That should give me 'normal', not sure if physical max/min will be that easy, unless someone knows that xxx can not exceed yyy, and if so, how do they know this? |
The service manual ( not owners manual ) states what are "normal" values for many items, and gives min/max for certain things.
But you are right, for certain things it will be by experimentation. |
Originally Posted by 08hybridok
(Post 193955)
Also what is 'critical' SOC, if one were to say sit in N with the radio on, 1) will the HV batt protect it self and shut off/revert to 12V battery & 2) when is it to low to start, require a 12V jump? I have had the SoC drop to 23% when working on the car before and it started fine. |
| All times are GMT -7. The time now is 03:04 AM. |
