Same Car, Different Oil
isn't it the same Escape Hybrid sold in US and Canada? also my car is a US car (I bought it from US but I live in Canada).
Anyway the manual says in US the engine oil used should be "Motorcraft SAE 5W20 Premium Synthetic Blend Motor Oil", but in Canada the oil used should be "Motorcraft SAE 5W20 Super Premium Motor Oil". Most Canadians live in the belt area near US boarder, why Ford recommand different oil for the same car? Why Ford does not recommand synthetical oil to Canadian FE?? :embarass: |
Re: Same Car, Different Oil
Any ideas? Thanks.
Originally Posted by Sphinx88
(Post 179253)
Any ideas? Thanks.
Mobil 1 Synthetic 5w-20. :) Some of us use Mobil 1 0w-20. Avoid the synthetic blend oil which costs as much as synthetic but has more frequently change recommendations. Go to Walmart or similar and purchase Mobil 1. The synthetic flows better at colder temperatures, last longer and may improve mileage. Why use anything else. |
Originally Posted by Billyk
(Post 179261)
https://www.greenhybrid.com/share/fi...l15505_sid.jpg
Ford OEM - FL-2017-B Mazda OEM - L321-14-302-9U (per GH) Purolator - L15505 (standard) Purolator PureOne - PL15505 Wix - 57203 K&N - HP-7013 (per GH) NAPA – FIL 2703 (Gold) NAPA- SFI 27203 (ProSelect) (2008) You can obtain the oil filter "wrench" at an autoparts store such as Autozone. I think this cost me $4.28 last year. You will need a socket (square) to remove it and then to tighten the new one on. Make sure you put the new rubber gasket on the filter cartilage prior to installation. The drain plug is not too far from the oil filter. Everything can be seen at the front end of the engine compartment if you are looking upward. |
Thanks again, I will see what there then try to change later. Last tank I got real 7.1 L/100km, really good, better than Toyota Echo.
