Replacement of Aux. Coolant Pump?
Has anyone had to replace the Aux. coolant pump? It is a small pump on the drivers side underneath the front end just behind the radiator, and mine is whineing something fierce... just wondered if anyone else has tackled this job.
I think I may do that, the MECS Pump, and flush both coolant systems and refill, since I have 51K on the vehicle and both pumps require losing fluid and replacing... Whatcha think? What's the process for the flush and should I buy a flush fluid and follow some process to properly clean it all out? Can you get everything out afterward? |
Re: Replacement of Aux. Coolant Pump?
Originally Posted by ddderek
(Post 248402)
does anyone have a part number for the other auxiliary pump i cant find it anywhere and my 06 MMH has been giving me some SSN problems. i have changed the mecs pump believing it was that, completely unrelated. ended up being the temperature gauge. in the process i changed out the water pump and thermostat. the only thing i can find that isnt working is that small auxiliary pump on the drivers side but cant find any info on it.
Originally Posted by john8919
(Post 252290)
I'm pretty sure this is the part you are looking for: http://www.fordparts.com/Commerce/Pa...&model=Mariner |
thanks guys but the part is working fine for me not the problem. vehicle stills cuts off above 3000 rpm. new mecs pump thermostat working water pump fine new temperature sensor.... any suggestions would be greatly appreciated.
i was under my 2008 suv and theres 2 mecs pumps from what i saw one is for the main engind and its located on the driverside infront of the electric motor, i might be wrong but thats just me i DIY everything on my hybrid
(Post 252290)
I know I'm late to this discussion, but I'm pretty sure Ford has issued a recall for these failing MECS pumps.
http://www.autoblog.com/2014/09/12/f...hybrid-recall/ I had the SSN problem a few years back. I replaced the MECS pump myself. After the recall was issued, I was able to get a refund from the dealer for my costs to buy the replacement pump. Hope this helps. |
I replaced my OEM MECS pump at about 51,000 miles on spec since I was seeing entries in here about it failing. Ford has a new design pump. If you order one (~$180 several years ago) you should get the new design one. Ford just sent out another recall to replace the original OEM pump. So you may be able to get a Ford Dealer to replace yours as part of the recall.
| All times are GMT -7. The time now is 08:19 AM. |
