P0138 Check Engine Light
1 Attachment(s)
Hi folks.
Just got an error code on my 2005 Ford Escape Hybrid with 90K miles: P0138 - Bank 1 Sensor 2 This I believe, refers to the O2 Sensor in the vehicle, only problem is, I'm not sure WHICH. I understand that Sensor 2 generally refers to the O2 sensor AFTER the catalytic converter so I think this is stupid question but if anyone can check the file attached and confirm that its #3 that needs to be replaced, that would be greatly helpful! Thanks everyone! |
Re: P0138 Check Engine Light
Hi folks, just want to update this post very quickly...
As it turns out, I did some snooping and decided to re-seat all sensors on the catalytic converter. Once I did that, the fault code(s) disappeared completely. :shade::shade::shade: I will mention, websites do mention changing O2 sensors after 75-85k miles. I believe the repair manual said to change them at 100k miles although I'm unsure about this. Anyway, take care everyone! ;) |
| All times are GMT -7. The time now is 08:17 AM. |
