Oil Filters: Fram vs. Motorcraft
I have a 2009 FEH. Upon the first oil change, I used the appropriate Fram oil filter, and I didn't look at the spent factory oil filter. As you know, inside the oil canister, there is a plastic cylindrical baffle that the oil filter element fits over. I assume that the baffle distributes the oil flow, so that the element is used uniformly.
I recently purchased the appropriate Motorcraft oil filter, and noticed that on the inside cylinder of the filter element, there is a similar baffle, which cannot be removed. Additionally, this filter with baffle fits over the baffle on the oil canister. Double baffling. So, does this mean that I should only use the Motorcraft filters? Thanks. |
Re: Oil Filters: Fram vs. Motorcraft
I think the baffle has less to do with distribution of oil and more to do with maintaining the shape of the filter.
That said, I've not been happy with the Fram filter. I suppose the filter itself is ok, but the larger o-ring that is supplied leaked . . . twice, two different filters. So, I've been using an STP filter form Autozone. Works like a champ. Major gripe here: Why the *choice expletive* are these filters MORE expensive than the fully enclosed spin-on filters?! Freakin' highway robbery. |
More expensive? Low volume means that the fixed cost have to be allocated to fewer units (tooling, set-uo, etc.)
That's really a cop out. This same filter is used in several Ford vehicles so there is plenty of market. I understand recouping tooling costs, but for this filter what they charge is ridiculous. There's almost nothing to this filter and not one gram of metal.
OK then. All of the suppliers of the filter are trying to recoup their design, development, tooling and set-up costs. Until one of them reduces the price, all of the various pricing analysts will attempt to get a much money for their filters as the market will bear. Same thing happened with the relatively low volume filter introduced with the 2002 Thunderbird. It finally dropped down from all suppliers when one of them decided to "Get competitive" and gain market share.
So don't stock up now, the price will come down sometime in the future. Just my opinion, nothing humble about it. |
It is the same economic law that controls oil prices and many commodities
The law of supply and greed. He who has the supply sets the price according to his greed level.. Hopefully all your competitors are as greedy and won’t force the price down... |
OK--got all the theories about the price of the filters. Take further gripes outside :angry:......now, anybody want to answer the original question?;)
Originally Posted by mustangbob
(Post 208637)
Double baffling.
So, does this mean that I should only use the Motorcraft filters? Thanks. But the 2009 is a new engine, does this mean a new filter? |
The best that can be said for the standard oil filters is that they get down to maybe 30µ particles and most are probably really 50 µ particles. There are clearances that are on the order of 8µ in an engine.
By far the most damaging particles are those that can touch both sides of clearance at once. I installed a Canton Racing Products filter that is rated at 8µ along with a 1µ bypass filter on my FEH. The 8µ filter required a different engine block adaptor. So far so good. |
Originally Posted by Bill Winney
(Post 208938)
| All times are GMT -7. The time now is 03:38 AM. |
