Oil change every 5k or listen to computer?
Do you get your oil changed every 5k or do you listen to the computer? Mine says 42% life left but I've driven about 10k miles.
Re: Oil change every 5k or listen to computer?
I tend to listen to myself. 3,000 for dino. 5,000 for synth. I live in the south which is hell on oil.
Originally Posted by sirfergy
(Post 119864)
I'd not exceed the 10k change interval that Ford specifies regardless of what the dash indicator says. |
Originally Posted by econoline
(Post 119886)
I thought the oil change indicator was a straight mileage countdown to 10k. If you've driven 10k since it was reset and it's now reading 42%, then it doesn't work the way we had thought.
You are supposed to change your oil every 10,000 miles with Dino or Blended oil. Or in 12 months, whichever comes first.
With full synthetic oil, you can change oil every 15,000 miles. You need to consider that this is a "Green" vehicle in more ways than one. Fewer oil changes is one way. Fewer oil changes, and a re-usable oil filter canister help reduce waste. The FEH runs the engine fewer hours than a traditional car. The FEH runs the engine at idle, amost not at all. If you change your FEH oil more frequently than above, then you are not fully understanding the benefits of a hybrid car, and you are needlessly wasteing money, and sending extra pollution into the environment. Ford says it is not required, but most people make the very first oil change sooner, during the break-in period. I changed out the Motorcraft factory oil at about 6500 miles. I used Mobil 1 and took it 10,000 miles the first time and the oil was still clean, tan colored, and translucent when I drained it. I used Mobil 1 and took it 15,000 miles the second time, and the oil was still in good shape. Visually, it was still clean, dark-tan colored, and translucent, after 12 months and 15,000 miles. The FEH is gentle on oil. I'd only change it sooner if you drive on dirt roads all the time. |
I use Mobil1 0-20 & change the oil & filter at 7500 miles.
It is overkill?? Probably, but I love my truck & plan to keep it a long time & it certainly doesn't hurt to change your oil more often........ ~John |
Originally Posted by gpsman1
(Post 119922)
Understand? |
I tend to go by the book which says 10K for oil changes. I figure Ford spent a lot on research and that is what they came up with. I am sure the engine will last longer then I will keep the car. Just my 2 cents.
Originally Posted by IndyBob
(Post 120051)
I tend to go by the message center indication myself. |
I had initially changed it at 1K but that's only for the first thousand miles, but now it's 10K.
