MPG on first-start electric
2008 AWD FEH, no NAV.
When I first start out in the morning (engine completely cold), the FEH turns on the engine, but apparently most of the propulsion is coming from the batteries. I say this because the Throttle Position Sensor (TPS) is set to a certain value - which varies, but is generally 16 - 18 - and does not change, and the RPM does not change. My energy meter goes to "assist". This is all normal for the FEH, and not new. This morning I was watching the guages, and I realized that my SG 2 was indicating about 28 MPG, until I let off the accelerator, at which point the "assist" meter went towards charge, the TPS did not change, but the MPG went to about 35 or better. I didn't think to check the RPM guage. Why would the MPG get better when I eased off the accelerator, if the primary propulsion was the electric motors? I would have expected the TPS to change to a lower number, indicating less gas was being used. FWIW, my TPS is never lower than 11. Any ideas? |
Re: MPG on first-start electric
There is a couple of statement in your post that need to be "corrected" and lets wait for the long time FEH owners and experts to post their reply.
Originally Posted by Billyk
(Post 197042)
Originally Posted by stevedebi
(Post 197043)
Hopefully not wwest, since he is on my "ignore" list!
(Post 197039)
What you said is true. For the first ( 30 seconds? ) of a cold start, you are getting primarily electric propulsion. But not exclusively electric propulsion.
Letting off the pedal you went from slight gas powered drive to no gas powered drive is my guess. See if you can repeat your data three times or more and see if you can nail down the pattern. I think the explanation will present itself. Carl's explanation is also very good, and kind of what I'm trying to say. The engine went from slight load, to no load. Fuel Trim probabably changed, and I gurantee RPM's changed, if only slightly. HTH, -John |
Originally Posted by gpsman1
(Post 197081)
FWIW, during warm-up, my 2005 is always at 1200-1300 RPM.
I know mine is done with warm-up when it drops to 1000 RPM. ( I also drive primarily between 3500 ft and 5000 ft elevation which may have everything to do with it. There are many variables to consider. ) In severe cold ( sub zero F ) the rpms are 1600-1700. Once or twice in very, very cold, mine would stay ~2000 RPM. We still don't have a good description of why that is. But many people report this, so it is assumed to be 'normal'. |
It was in the mid 50s this morning, and I checked it again. The RPMS were at about 1550 (I don't have RPM on my SG, maybe I'll try that next). The same thing happened; the TPS remained at 17 and the RPMs did not appear to change.
It is obvious when the FEH exits this "first start" mode - the RPMs and the TPS begin to fluctuate based on my accelerator pedal imputs. |
Something else unusual happened this morning. I was at full warm up (having driven for 15 minutes), HWT at around 160, sitting at a stop with the engine off, waiting for a stop light. When I accelerated, the FEH went into the "early morning cold start" mode for about 15 seconds - the engine went to about 1550 RPMs and the TPS stayed at 17, regardless of how hard I used the pedal (within reason, of course). After about 15 seconds it reverted to normal operation.
I sure wish I could figure out what enabled this behavior - I could use it to accelerate to cruising speed on a regular basis. I think I may have stumbled on a programming quirk in the FEH computer module. Of course it may only occur at certain environmental levels - it was damp this AM due to rain, for example, and about 55 degrees. |
| All times are GMT -7. The time now is 11:58 PM. |
