Master MP3/Wiring Thread
Okay, I'm sick of the billion threads here about wiring connundrums, thoughts about MP3/IPod Installation, etc.
Discuss it here, not in a new thread. There are some links out there, someone can post them about their success stories installing/wiring things. https://www.greenhybrid.com/discuss/...64.html?page=1 |
Re: Master MP3/Wiring Thread
2 Attachment(s)
I agree with Rich (Pravus Prime), this information need to stay on one discussion thread.
First of all, the information I found IS NOT in a sales brochure. It can be found online at www.FordAccessories.com. Then you select the vehicle you would like to download the accessories catalog for. Secondly, I had posted this information on the string "iPod My Ride". I have downloaded the Accessories catalogs for the 05, 06, and 07 model FE and FEHs to compare.This part is only in the 2006 Ford Escape and Escape Hybrid Accessories Catalog. This information is not in the 2005 or 2007 Ford Escape and Escape Hybrid Accessories catalogs. "Have you looked at the accessories for the 2006 FEH? There is an accessory titled "TripTunes" you would be interested in. It is part number 19C142. The description is as follows: "Take your tunes on the road! Now you can connect most portable audio players (MP3, iPod, iRiver, ScanDisk, etc.) plus portable CD and cassette players, right to your in-dash radio. Just plug your player into the harness - a 3.5 mm stereo connector provides the interface so you can listen to music through the radio's speakers and control the volume. Audio connection is housed securely in your vehicle's glovebox or center console. Base Part No. 19C142. In the downloadable fordaccessories pdf file, it is on page 6." I have purposely placed all the KEY words/phrases on BOLD. This way everyone referencing it can easily find this information. I have also included the Accessories catalogs for 2006 and 2007 model FE and FEHs. When I tried to upload the accessories catalog for the 2005 model, I was "told" the file was too large. If anyone would like a copy and can't find it, I can try to email it to you. Good luck and hope this helps. Rich |
The 2005 Ford Escape Accessories catalog can be found at http://www.fordaccessories.com/catalog/2005%20Escape%20Genuine%20Accessories%20Catalog.pd f
For some reason, Ford pulled their 2007 Accessories catalogs off of their web site. But here is the link to request/download a catalog. http://www.fordaccessories.com/requestcatalog.aspx Good Luck |
http://www.allfordmustangs.com/forum...ad.php?t=48851
According to a poster in this thread who is an accessories retailer, the TripTunes adapter is an FM modulator similar to those used by XM and Sirius radio users. This is not nearly as good as a direct connection (I have an FM modulator for my Sirius) and it is a little better than the wireless FM modulator but far from "CD quality". If I were looking to interface an iPod I would look at one of the PIE systems that tap into the CD changer to feed a line level (RCA) signal to the headunit. The downside of that is that the CD changer must be "powered up" for the PIE system to work so you always have to keep at least 1 CD spinning in the changer. |
Here's documentation on my particular installation --
Vehicle: 2006 Ford Escape Hybrid FWD w/stock Navigation Radio (Visteon) Device Desired to Interface w/Radio: 4GB iPod Nano Interface Chosen: FRDW/PC-POD interface* *The initial interface unit I received was cranky, but the replacement has been issue-free since the moment I plugged it in. Shop around as I was able to find it for cheaper than $120, and it's available for less but I was leery of anyone who'd charge $89 or so for it. Level of Difficulty to Install: 2 on a 10 point scale, only because it might take a flashlight and a minute or so to locate the plug you need to disconnect, get the plug disconnected, and plug in the PC-POD cable. What I Like About It:
Caveats:
Another PIE option is the X3 interface. I currently have the same configuration as GeekGal. I like the fact that it charges the Ipod and you can use it through the NAV radio. You cannot control the Ipod separately though.
The PIE X3 has a T wiring harness with a switch that lets you still use the CD changer as well as 3 other devices plugged into it via RCA jacks. The PIE X3 will not charge the Ipod and you have no control via the NAV head unit but you can switch between inputs if you have a satellite radio, etc. BTW, I have a PIE X3 system that will fit into a FEH with NAV system and CD changer under the passenger seat if anyone is interested. |
I understand, I just wanted to make sure that people know this is not some type of line level direct connection since that is what Ford mkes it sound like in their description.
My first post, hopefully i dont get off on the wrong foot.
I just purchased my FEH 06 (used actually, bout 1k miles on it). It has the NAV + 6 cd changer under the passenger seat configuration. I would like to be able to attach both my iPod (60 gig iPod video) and get Sirius Sat Radio. If i'm reading correctly, my only option will be to get the "x3" piece of equipment and use that to attach both an after market Sirius receiver and iPod... and i'll have to manually toggle back and forth on the x3 unit in order to switch between them. Is this correct? or do i have a better option available that i'm missing? Thank you for any help/info. |
I think the X3 comes with a switch that you can mount somewhere to choose your source. In terms of sound quality, this is probably your best bet unless the PC-Pod can be integrated with some sort of audio switch to allow you to input the Sirius feed as well. I say that because the PC-Pod will allow control of your iPod from the radio controls whereas the X3 will not.
| All times are GMT -7. The time now is 12:51 AM. |
