How do I drain the engine coolant?
I was under my 2005 FEH. I couldn't find the drain spigot in the rad to drain/change the engine coolant. I did notice the heating pump( in EV mode). Do I drain the system by removing the hose at the pump?.
Re: How do I drain the engine coolant?
bump:angel: thanks!
Remove the lower radiator hose to drain the radiator.
