Highest Mile Escape
I just saw a thread on the honda forum about a 200,000 mile civic.
Since the stories we read here tend to be people that are experienceing problems with their escape I just started to wonder, Who here has the most miles on the Escape/Mariner/Trib. ?? |
Re: Highest Mile Escape
Here's a 2007 Taxi FEH on eBay with 260,000mi. The poster goes on to say "I have had other Escape's in stock with over 340k miles."
eBay 2007 Ford FEH |
Originally Posted by MyPart
(Post 232917)
eBay 2007 Ford FEH that the FEH is a more then just reliable vehicle. Others are in Chicago and San Francisco. Just a few months ago the SanFran fleet retired 10 FEH's with over 300k. http://www.youtube.com/watch?v=KeuRkoLuY5U for a look. My favorite is: http://www.earthcam.com/usa/newyork/timessquare/ cam2. Watch'em go by one after the other. Even more fun was watch'em go by during that really nasty snow storm a couple weeks ago. |
We have 175k mi on our '06. We're the original owners. The wife used to spin on about 40k mi/year until she got a different position with her work. We're down to about 1/2 that now.
Originally Posted by jworth
(Post 233255)
I haven't had to do a lot to it. When it was fairly new we had the rear brake rotors replaced under warranty and also a rear strut. Since then other than routine maintenance which I do myself, I've changed the MECS pump and the blend door actuator. I don't think the MECS pump had failed yet but it seemed to be intermittently noisier than it had been and I wanted to change it as preventative maintenance. Nether of those changes cost a whole lot. I added adjustable rear control arms so I could set the camber. I added cam bolts on the front so I could change the camber there as well. FWIW, I can actually get a true alignment now. I've changed the rear brake pads. I relocated the heated seat switches into the console. I suppose that's about it. The most expensive singe item in that list that we had to pay for was probably the MECS pump. That's been a while but I'm thinking that was in the neighborhood of $150, again with me doing the labor.
http://www.greencarreports.com/blog/...000-plus-miles was a story about the 300K mile FEHs. http://www.autoblog.com/2007/04/04/f...new-york-stre/ from 2007 mentions 175K mile NYC FEHs.
If one thinks a 200K mile HCH is a big deal, look at http://www.ctvbc.ctv.ca/servlet/an/l...shColumbiaHome. One Prius has >1 million km (~621K miles) and needed a new HV battery at 700K km (~435K miles). |
134,000 FWD 05 Escape Hybrid. Never been to a dealer, bought at 25K with salvage title after mild rear hit and already repaired when I picked up. Never seen a mechanic- or needed to other for state inspection.
2 sets tires, 10k oil changes, 50,000k fuel filter changes, etc. Plugs at 1,000,000. 1 12v battery at 5.4 years. Even original brakes-- but that can't last forever. Operated in Iowa and MO at over 95 degrees in summer, teens and below in winter- air works, heat works, everything works. I gotta believe with this vehicle it is age rather than total mileage that will be it's downfall- as the electronics get older and seals begin to harden on the delicate electronics- stuff will certainly happen- so I am working to rack up the miles and not worrying about it. 2wd drives like 1 wd in the snow and is a real danger in hilly, windy country- but that is only drawback. After this praise- it will probably die tomorrow... |
Originally Posted by Piquant
(Post 233467)
I gotta believe with this vehicle it is age rather than total mileage that will be it's downfall- as the electronics get older and seals begin to harden on the delicate electronics- stuff will certainly happen...
I wanted to comment on the electronics. Most of the sensitive Hybrid stuff is in the eCVT. I've quite a lot of experience with military and industrial system ( servos mostly ) and as long as they are not abused they could last a very very long time. Much longer then the usefulness of the vehicle. Heat and cycling ( being turned on and off ) are the enemy of electronic systems like this. Extreme cold can effect it and you see that all the time here. I put very few miles on my vehicle ( 06 FEH ). Typically no more then 300mi/month. So I'm gonna be interested in things like do you change your synthetic oil once per year rather then at 10,000 miles? I say yes. |
"Heat and cycling ( being turned on and off ) are
the enemy of electronic systems like this. Extreme cold can effect it and you see that all the time here." I live where the winter is quite cold, -20ºF or colder not uncommon, and I've taken to just leaving the block heater plugged in all the time. Used to try and lead using it by, say, 3 hours or so, but I get quicker transition to the battery this way. |
| All times are GMT -7. The time now is 07:35 AM. |
