Help!!! Escape leaking yellow fluid from driverside rear?
Hi Guys,
Noticed a basketball-sized puddle of yellow fluid coming from one of the lines by the driverside rear wheel just in front of the suspension coil. Looks like maybe one of the clamps caused a crack in the line? Leaking right at a clamp.. Anyway, is that brake fluid? and is there anyway I can fix it or do I have to take it to the dealer$hip?:( It's an '08 FWD Hybrid... I'm assuming this is a non-warranty issue? Any rough estimates on cost of repair? Quick responses are much appreciated, Thank you. |
Re: Help!!! Escape leaking yellow fluid from driverside rear?
Originally Posted by JCPerformance
(Post 252453)
Hi Guys,
Thanks... This may seem like an obvious question, but are all $tealerships supposed to have the same part and service prices?
(Post 252453)
Hi Guys,
$320 for brake bleeding? Talk about getting bent over. I've replaced the fluid in alot of cars that had ABS with a Mighty Vac. Not sure why it would be so different just because its a hybrid.
Originally Posted by FjordHybrid
(Post 252461)
Probably unlikely, but that could be your rear a/c line leaking. They put yellow dye in when they charge it at the factory.
Originally Posted by lefty
(Post 252468)
(Post 252461)
(Post 252461)
Originally Posted by us035976
(Post 252488)
BUT, an A/C leak would be freon and that wouldn't leave a basketball sized puddle on the ground. It would disappear into the air. Or am I wrong about freon.....??
