Electric Vehicle Forums
-   -   Getting to POI (and others) While Moving (https://electricvehicleforums.com/forums/ford-escape-hybrid-26/getting-poi-others-while-moving-5214/)
VietVet'67 Dec 31, 2005 09:46 AM
The reason I started this New Thread is that I see the inability of accessing the ‘Points of Interest’ (POI) to me seems to be a separate, unique NAV System Gripe.
This is not to say the other Gripes - Trouble with using Handsfree options, the unit always comes on with radio or CD and if you turn the radio off the whole system doesn't function except as a clock (Actually you are turning the entire system off – not just the radio), having to hit the liability waiver every time you turn on the NAV system, the screen is to small, I don’t like the voice (mute it) – are problems or annoyances, but are totally unrelated to this one issue.
One other - the inaccuracy of the maps themselves or the sometime insane route the system suggest or putting all the data on the 11 disk to One DVD. The discrepancies related to Maps, Routes and Points of Interest are not a defect of the basic NAV system – but of the data supplied by NAVTEQ, You'll find NAVTEQ data onboard most in-vehicle navigation systems sold in North America and Europe, they were the ones selected by Ford for their systems information. These problems need to be reported to NAVTEQ – don’t be in a hurry for a fix – seems they make major updates to the data base on the disk every one to two years.
All other NAV-Radio-System Functions that are integrated into the unit need to be taken up with Ford. They outsource the units control software to another company and changes are sometimes slow because of the chain of command and the bureaucracy. The number to reach for these problems is 1.800.392.3673.
Following are ‘Replies’ posted on the ‘NAV system Gripes’ Thread, that were related to the subject.
Originally Posted by cdbrow1
Why does Ford and the liablity police require the following two things -
That the car be at a dead stop to use the NAV system (enter data etc.). The car can detect when my passenger seat is occupied so why can't it just accept inputs from the passenger when the car is in motion. I hate having to stop just to find out where I need to go.
Second why do I have to hit the liability waiver every time I turn on the NAV system. The accept button is always a pain in the butt to find and hit while driving, which is sort of in conflict with item #1 above.
Chris Brown
Originally Posted by stevewa
This appears to be common to all built-in navigation systems. I strongly suspect there is legislation in place to cover this.
Steve
Originally Posted by VietVet'67
To start off let me say I am and have been happy with the operation and usefulness of my NAV unit except for -
and I know this is an on going grip and nothing new, but it is one of my pet peeves. It is the inability of being able to access the ‘points of interest’ while the vehicle is in motion. Heck you can do almost everything but cook a pizza with it while doing 70 in heavy traffic. I know a lot of what we can do with the info screen – check the FE, how the system is functioning etc –has nothing with the NAV section of the unit. I have been in contact with NAVTEQ (supplier of the data disk) and they say it is a ‘safety issue’. If it is a matter of having to take your eyes off the road then we shouldn’t be able to (beside all the other stuff) zoom in and out of the map screen, change from map to NAV, delete or detour your route . . .
Generally the things I would like to have access to are things like – where is the next rest stop or nearest gas station, find a Hospital in an emergency etc. All of this is already there and no input is required – just a selection of what and which one you want. I sure wouldn’t want to have to pull over here in the Atlanta area on our GA 400 (everyone thinks that is the speed limit) to have to find the nearest hospital or other emergency location – I WOULD need them if I did pull over. I would say if you were in an emergency the safety issue would be how QUICKLY I could locate something.
There is no way of foreseeing what you might need along a trip. Did anyone find out if it is say Federal Reg on installed units or has anyone found a work around on this one?
Thanks - Phillip
Originally Posted by GaryG
Over on the yahoo site about a month or so ago, I read a blog on how to bypass the Nav Systems ability to know you’re moving. It was a simple switch installed to make this possible. I think GPS1Man may know how this is done. Ask him
GaryG
The short answer:
Yes you can install a switch to defeat this function by fooling the navigation into thinking you are not moving.
Steve.
Thanks Steve & Rich - The only problem I see with a switch to fool the NAV into thinking you are not moving is that it would probably negate any distance data that would be sent to the FEH system for computing FE & DTE.
Gary –Found this message already posted on the Yahoo forum where you had posted a message “gpsman1 - I already hacked the GPS system!;) - John.
Thanks Guys for all the help and input - Phillip
After sending an email questioning NAVTEQ (The supplier of the NAV Map data disk) about why I could not access 'Points of Interest' while the vehicle was in motion I asked – ‘was it there decision of safety or was their a law etc prohibiting this. Here is there reply.
Subject: Points of interest
Phillip,
Thank you for contacting NAVTEQ.
The driver must not attempt to operate any detailed operation of the navigation system while the vehicle is in motion. Give full attention to driving and to the road. Pull off the road and park in a safe place before performing detailed operations. This is a safety feature of the navigation system itself. Please contact Ford at 800-392-3673 to suggest enhancements to their system.
Phillip
VietVet'67 Dec 31, 2005 09:49 AM
Re: Getting to POI (and others) While Moving
"Warning"
This Modification Could 'VOID' Your Warranty!!
OK – I think I have at least one good answer to the problem of not being able to access the ‘Points of Interest’ (POI) while you are moving.
Thanks to John – ‘gpsman1’ (here) and ‘GPS man’ on the ‘Yahoo hybrid_ford_escape’ forum, for taking the time and patience to give me his answer to the problem. Plus a few others from the Yahoo forum.
The signal that the unit is using to detect motion (VSS Wire) has to be interrupted to fool the NAV into thinking you are sitting still. If you have the parts ready it should take 30 mins or less.
Let me start out in saying that there are two different ways to do the physical modification, both call for pulling the unit out. One requires cutting a wire and placing a switch in line and the other uses male and female connectors to make the splice and put the switch inline without cutting any wires.
  • You can remove the NAV/Radio unit using a radio removal tool that should be available at most auto parts or even WalMart. They are two (2) "U" shaped brackets with barbs on the end. Insert the "U" shaped keys into the holes as shown (push till they click into place). While pushing (pressing) the keys outward, and pulling, the unit should slide forward and out of the dash. Image of Unit with Removal Tools
  • Once you have the unit out, you can rest it on the shift lever so you can look at, and work on the unit. Image of Unit Resting On Shift Lever
  • You need to locate the VSS (Vehicle Speed Sensor) wire (gray with black stripes) that sends the speed signal to the unit. By interrupting this signal you fool the unit into thinking it is sitting still. There are about 5 different wiring harnesses going into the unit. Looking at the unit resting on the shifter the harness/plug you are looking for will be on the right front (closest to you on the right). It will be a 22 pin Black harness that has only 3 wires going into it, the gray with white stripes wire on the top right closest to you will be the VSS (Close-Up Image of harness/plug). The other 2 are a Brown/Purple and a Black/Purple. Image of Back of Unit Identifying VSS Wire
  • This is the wire you have to cut and splice with some 20 - 18 AWG wires long enough to reach where you will mount the switch. There are a couple of ways to do this.
  • If you are hesitant in cutting the VSS wire, there is a way around it. You can get the correct size male and female connectors and plug the factory female connector (the one that is currently going to the NAV unit) into a male connector attached to the lead going to the switch. Then run the other lead wire from the switch and attach a female connector to that wire and plug it into the NAV unit.
    That way you will not have to cut the wire – plus if you did have to take the NAV unit back in for service, you could just unplug your wiring and plug the original factory connector back to the NAV unit. They will never know what you have done. Radio Shack sells Quick Dissconnects that should work fine.
  • The three wires that are going into the plug are wrapped with tape so you will have to use a sharp knife etc to cut this back far enough to leave about 1 1/2" to 2" of wire coming out of the plug before to the splice cut, plus enough room to splice the other end. It is best to use small wire nuts to secure the splice but in a clinch wrap each splice with a generous portion of electrical tape.
  • Route the two splice wires to where you will be mounting the switch. If you are going to place them where I did (Image of Button Placement) it is easiest to twist the wires together, for strength, and feed them from the bottom up to the opening in the dash.
  • For a professional installation look:
    • From GPSman - You can easily press out this blank black square, (from the back forward when your radio is out) and mount a similar sized switch to the "set" button, and place it in the already die-cut hole. NO DRILLINGREQUIRED.
    • You could get a replacement hole cover (on the FEH the blank one is the second from the right) and drill that to put the rocker switch in - then if you needed to have work done on the Radio/NAV you could easily replace the blank, take the wires with the male and female connectors off and replace everything just like it came from the factory.
    • I put mine in an inconspicuous place on the passenger side and mounted it there. I found one at Radio Shack, a SPST Rocker Switch Model # 275-693- rectangular with small white 'ON' mark that worked and looked very good. Close-Up Image of Switch
  • Re-install the unit and you are done.
I had a few Reservations about doing this, but most have been alleviated by the research and road work by GPSman and my self. I was worried that doing the modification it might mess up the NAV systems instant or 15 min average EV.
Answer from GPSman
: I can confirm that the break in the VSS wire DOES NOT affect your instant or average Fuel Economy. I drove around all day today with the button off, and fuel economy, both instant and average adjusted normally. (12.23.05)
After doing the modification I can concur his observations. I have driven with and without the switch on and there is ‘NO’ interruption of the instant or average FE – plus you can also access the ‘Plan’ and ‘Pan’ feature that is not grayed out. Image showing NAV with POI showing as available @ 25 MPH.
There is one draw back. During the time the signal is interrupted the GPS unit thinks it is in the same place that you were when you hit the switch to Off and then back On - so your displayed position will not change during this time. If you do frequent turns in the city, the system updates quickly. If you are going down a long, straight highway, the system takes a few minutes to notice you are not in the right space on the map and do a correction update.
There are a couple of things you can do to get back on track. You can by ejecting the NAV CD and re-inserting will force an immediate re-locate, plus the POI you just searched for will be in your recent places list, so you will not need to "pause" the system again, or just wait a while and it will finally get back on track.
There are quite a number of ways to mount the switch – I used the one from Radio Shack. I put lug type plugs on the end that would be going to the switch and twisted the two 18 AWG wires to give stiffness for threading them up from the passenger side of the cover. Drilled a 3/4" hole in the upper back portion of the cover and it looks great.
If anyone does this mod I would like to know how it came out. Just send me a message here - Thanks - Phillip
GaryG Dec 31, 2005 01:28 PM
Phillip, excellent job putting that together! It would only be fair to John if you put this in a folder on the Yahoo site if you havn't already. The pictures are just great and now I see how the tools are used to remove the unit.
My thinking was to order an Emergency Flasher switch from Ford and relabel it and put it in the unused slot like the rest of those buttons. Do you see any problems I might have? Anyone?
GaryG
VietVet'67 Dec 31, 2005 02:07 PM
GaryG
Gary the only problem I had between getting another Hazard button to use as a switch and the one I got was about $45.
Phillip
VietVet'67 Apr 18, 2006 06:33 AM
Up-Date
WaltPA Aug 7, 2006 07:25 AM
Just in case anyone is interested...
Ford Expedition & Escape 12 CD Map Set 2005.1
dbeaty2 May 26, 2007 04:30 AM
Question about installing a switch for the speed sensor wire.
How does this effect opperation of the nav when you use the switch?
Do you have to hit the switch, select the POI ect, then hit it again? I would assume that when it's not engaged the vehicle position on the nav does not update. Or does that wire ONLY control access to the POIs.
Dave Beaty
jmorton10 May 26, 2007 11:18 AM
Dave Beaty
When the switch is off, the NAV stops updating your position.
When you turn the switch back on, the NAV will reorient itself after driving a short distance.
~John
