FEH 2006 correct thermostat
Hello
I got an error code 128 that say that thermostat is faulty. Researching I found that two motorcraft part no. fits the car. the RT 1194 and RT1193, but they are different, and I want to remove the old thermostat only until I have the replacement in my hand. THe links in amazon are: http://www.amazon.com/Motorcraft-RT-...ar=1&carId=001 http://www.amazon.com/Motorcraft-RT1...ar=1&carId=001 Also I want to know if the gates thermostat is a fair replacement since In my country I can get a replacement in any shop, but need to have the correct part no. If you have it or know where i can find it please let me know. I have read that the wrong thermostat can give problems. My FEH is not going into electric mode too often, only after 15 minutes of warmup and after that I can not stablish a pattern when it goes in to electric or not. maybe it is the thermostat. I wait for your help and knowledge. Regards |
Re: FEH 2006 correct thermostat
Originally Posted by webcorrecto
(Post 235604)
Hello
Check the required temperature rating of the thermostat. Keep in mind that this engine design is used across many cars besides the FEH. So there are likely several thermostats that "fit." I'm wondering if the electronics controls are far more sensitive to the proper operating temperature than with non-hybrid applications.
So make sure the part number you select is listed for the hybrid application and for the year of your FEH (looking up by VIN should do that). The year of the FEH may make a difference since Ford did change their software with the 08 model year I believe. Whether this affected the operating temp or some other facet of your FEH I don't know. Mine's an '06 model year and I've had nothing like this come up. |
Originally Posted by wptski
(Post 235607)
The '06 FEH Workshop Manual doesn't list the part number but try this site http://www.fordpartsgiant.com/parts/...y_rt-1163.html as it has spot to enter your VIN which "may" help you get the correct part.
There are many Ford Dealers who sell at a discount on-line that do a search with a VIN for the right OEM part. They often provide a phone number so you can call them direct with your VIN number and order the part. Some of these dealers can be paid through PayPal for a 2.9% fee they charge at the selling price. This should work for people out of the Country also. GaryG |
Thanks guys, according to the website the correct part is 4Z8575B with the plastic housing, and the thermostat only is rt1193, the difference I can see is that the gasket is an oring, and maybe the size is different.operating temp is 190f, I reviewed stant website just to check and I see that the part is 48708 and is rated to 180F , 10° less, so I agree about using original parts.How often is it supposed to be replaced?
Regards |
(Post 235640)
Regards You replace them when they fail. Most often they stay open and your engine won't warm up. I had one where it warmed just enough so the engine would go into closed loop at a traffic stop but went open loop at speeds during cold weather. Would have never caught it without using a scanner one day. |
In the early 70s I had one stick shut. Everything worked fine until I was halfway to somewhere and the radiator cap started lifting on overpressure... almost ruined a whole day as I was halfway from anywhere!
