Failing HVTB and Failing Hybrid cooling system? P0A81, POA1F, P2521, P2524
Hi
I have a 2006 FEH with ~120,000 miles. It mostly drives fine except I am noticing that it increasingly seems to lose charge over night or within a few days of not being drive. It turns on and drives but with no hybrid assist/very slow acceleration for the first ~15 minutes of driving. The hybrid cooling system also seems to be faulty in that the battery will heat up and not allow the vehicle to kick into hybrid mode. There is a short window (between 15 to 45 minutes of a given drive) when the battery is charged enough and cool enough to allow Hybrid mode. (A mechanic recently told me that if the battery isn’t charging because it is overheating it might be why it has low SOC the following drive… seems plausible to me) I have BCM codes P0A81-60 and POA1F-20 and PCM codes P2521 and P2524 (screenshot attached) I have never gotten a stop safely message while the vehicle has been warm and running ForScan for the last month or so I haven’t seen the hybrid battery get hotter than 108 even while be driven for hours on end on recent Death Valley road trip From ForScan I also have seen a large difference in SOC and temperature between individual battery cells. For example the max charged cell will have 80% SOC while the minimum cell will only have %40 SOC. And once at “operating” temperature cells with have a ~20 degree range from hottest to coolest. Is this normal or does this indicate bad cells? (screenshot attached to illustrate point) Other potentially pertinent info: The low voltage under the hood battery seems to be fine and AC blows pleasantly cool in the cabin. Both the HVTB service harness was replaced and BCM was reprogrammed in 2018 ~40,000 miles ago. Over the 50,000 miles I have owned the car I have gotten reliably between 24 and 27 MPG and haven’t noticed any declines with the recent increase in issues. I wonder if these issues have always been present and are getting worse? Questions:
https://cimg9.ibsrv.net/gimg/www.gre...937494398b.jpg P Codes present. https://cimg8.ibsrv.net/gimg/www.gre...8c4342657f.jpg ForScan Info I have been keeping an eye on. |
