E3 spark plugs, will you save gas?
Has anyone used E3 Spark Plugs? http://www.e3sparkplugs.com/
They claim...
Re: E3 spark plugs, will you save gas?
If these spark plugs do this, then why are they not a standard feature not only on the hybrids but every other vehicle?:confused:
Originally Posted by Billyk
(Post 156405)
I guess the same could be said about K&N air filters. |
I have tried Bosch +4 which usually give a little bit of an improvement because of the electrode design. I got nothing. So I doubt these will do any better.
Originally Posted by Mark E Smith
(Post 156475)
I noticed that the engine was REALLY noisy at a 0 degree startup. I am wondering if that is just a sign of really low compression, in any case, I havnt found any information on what the compression actually is.
So my point is, I dont think lower compression engines benefit as much from different plugs. I had orginally though about different plugs but have held off so far. Just a theory. I will probably put new plugs in around 25k miles. |
I will probably put new plugs in around 25k miles. Plug design has more to do with the swirl inside the combustion chamber and the direction of the flame front. A standard "hook" type plug directs the initial flame front to the side. A Bosch +4 type directs it down. Pent roof style combustion chambers (FEH has one) generally benefit from a down directed. But this also depends on ignition timing, compression fuel octane etc. I doubt the compression is much different on a cold engine than a warm. |
Those claims are usually when comparing to the very old plugs being removed. Replacing old, worn out plugs with any type of new plug, will bring improvements.
My experience is that lower compression engines benefit more from enhanced spark.
There is a file floating aqround these this forums somewhere from last year (41 slide presentation ) that lists the compression as 12.3:1 (on slide 12).
To me with this high of a compression and not needing premium fuels just boggles the mind:omg: On the 88 & 94 Jag XJ-S's I once owned (5.3 & 6 L) with 11:5 compression you were asking for trouble if you used low grade (and doing a engine rebuild due to detonation is not fun or cheap!) On those engines more poeple swore AT the +4 plugs and actually got worse performance (and seemed to foul quicker). A lot of us used the NGKs and were very happy with the performance of those plugs. I did try the +4 on the Jag and removed them, so I was one of those swearing & they ain't cheap either! |
| All times are GMT -7. The time now is 12:11 AM. |
