Dealer is trying to convince me to drain and fill cvt yearly
I just picked up a 2008 4wd with just under 105k miles. I planned on getting the cvt drained and filled just because I don't know the full service history of the vehicle and for the simple fact that almost every other cvt out there demands service before this many miles. I read this forum a lot before I bought it so I know some say not to change it at all but I'm a little old school with my cars. Anyways, has anyone ever heard of someone saying a cvt needs new fluid every year or twice a year if towing? I haven't dealt with this dealer much since my last truck was a Chevy, but they seem to already be getting off on a very bad foot with me, so opinions?
Re: Dealer is trying to convince me to drain and fill cvt yearly
The FEH uses a PSD to "simulate" an actual CVT. The PSD, Power Spilt Device, uses 2 electric MGs, Motor/generators, and planetary gearsets. No clutchs, no frictional wear surfaces.
"ATF" should be good for the life of the vehicle. |
If the fluid doesnt look right and looks like a brown or black redish color you probably want to change it. It should be a cherry red color...I would change it regardless because you are the new owner and that way you will know for a fact that it has been maintained.
Originally Posted by cje2310
(Post 240764)
And...ATF = cherry PINK, and mostly transparent. Pink, as in the juice in a bottle of maraschino cherries. |
From what I have heard wwest you don't actually own an Escape Hybrid at all, so in the future please refrain from posting on my threads. That being said it does in fact use automatic transmission fluid because at least one of the components requires the use of it. On top of that it can be checked because there is a level check hole, doesn't take a whole lot of ingenuity to put something white in there and check the color and also check the smell to see if it's burning.
Originally Posted by hondarider90
(Post 240772)
Clearly it is not exactly the same because they do not even use the same TYPE of fluid from you saying mine doesn't take ATF, either that or you're wrong about your Prius. Either way the Escape Hybrid uses ATF and I would rather just hear from people that know about the Escape hybrid specifically, if I wanted general information about hybrids I would not be on a model specific section of the forum.
(Post 240734)
Your statement implied, clearly implied, a lack of knowledge of the differing types of CVT's currently available in the marketplace. I have little doubt that a "conventional" CVT would require service, ATF or no, on some defined interval. On the other hand the PSD type with no clutches, drive belts, etc, is unlikely to need service for the life of the vehicle. And as you were so kind to point out, checking the condition, level, color, dirty, burned, is not nearly as simple as with a conventional automatic transmission having a dipstick. Speaking of which are you aware that most modern cars now come from the factory absent a dipstick...? |
(Post 240779)
Originally Posted by wwest
(Post 240781)
| All times are GMT -7. The time now is 12:18 AM. |
