Can't start my Ford Escape - Flood damaged - Please Help!
Hi!, I love this forum!! this is my first post ever! =D
Recently i had bought a flood damaged car from an online auction for salvage cars, It's a [Ford Escape Hybrid 2008] [4,500 Mile] flood damaged and i need to fix it up! when i try to start my car, nothing happens at all, although the car is flood damged, the electricity is working fine!,and the engine got no water at all!, when i had plugged it with a computer scan; the computer showed two error codes: p0a7a, p0a18. i had searched the entire web and i got nothing at all! anyone could help? please! :D big thanks in advance!. |
Re: Can't start my Ford Escape - Flood damaged - Please Help!
You'll should buy the workshop manual for a project like this.
p0a7a = "Generator inverter performance" p0a18... I can't find in my 2009 manual. I'm going to assume that your HV battery could be too low to start. |
Was the scanner a Ford scanner that can read hybrid equipment? The P0A18 DTC is "Motor Torque Sensor Circuit Range/Performance.
Causes - Traction Motor AC (TMAC) circuit open TMAC circuit shorted to power or ground Sounds like you have possible serious eCVT internal problems. Your Transmission Control Module can be reprogrammed to see if this solves the problem but the internal repair of the eCVT is not possible according to the manual. GaryG |
1 Attachment(s)
You can have access to the workshop manual and wiring manual online 1 month($20) the one I took and save what all you want in pdf.
Your subscription to service information includes, workshop, wiring, Powertrain Control/Emission Diagnosis and Technical Service Bulletins. Workshop Information; Includes comprehensive instructions, procedures, approved specifications and detailed illustrations. Wiring Information; Includes component locations, circuit descriptions and troubleshooting hints. PC/ED Information; Provides engine diagnostic procedures in conjunction with the workshop and wiring diagram manuals. Technical Service Bulletins; Provides latest revisions to service procedures This is on http://www.helminc.com/helm/search_s...&class%5F2=FCT Hope this could be usefull for you sample: |
Ooo doesn't sound good, My input would have been to check the fuel relay in the pass kick panel. Altho it was 'flood' damaged, maybe it got a sudden momentum jolt. I saw a FEH for sale localy once that said wouldn't start, I told them that, they clicked it and got it to do more, but still wouldn't turn over.
Even if you fix it, can you leagly register & re-insure in your state? Maybe you can find another good deal on a totaled one and start swapping parts? |
Thank you guys very much for your help :D
i got a BIG Problem..we just took the Engine down and there is a broken cylinder & a several damages at the engine[at the bottom - middle] it's like the car was heated and then it's suddenly frozen! this is painful.. :S |
Originally Posted by soom-1
(Post 221561)
i got a BIG Problem..we just took the Engine down and there is a broken cylinder & a several damages at the engine[at the bottom - middle] it's like the car was heated and then it's suddenly frozen! this is painful.. :S Good Luck and let us know what you do. GaryG |
Hello OP, what was the outcome on your flooded FEH? I recently got mine flooded. I was wondering if your FEH was able to be recovered.
Originally Posted by avinator
(Post 270824)
will do, thanks!
