Electric Vehicle Forums
-   -   Buzzing/Clicking noise behind dash (https://electricvehicleforums.com/forums/ford-escape-hybrid-26/buzzing-clicking-noise-behind-dash-20251/)
deemac Nov 11, 2008 07:32 AM
Hi Folks,
I've noticed on my 08 FEH, when stopped or parked, with the ignition on; a clicking and buzzing sound coming from behind the dash. It is not always there, but seems to be there more often these days, even with HVAC and radio powered off.
Any thoughts?
Thanks,
Darren
'08 FEH
MyPart Nov 11, 2008 08:03 AM
Re: Buzzing/Clicking noise behind dash
Does this happen continuously or just for a few seconds and then stops? Are you familiar with the sound of the brake system charging(key on)/discharging(key off) itself?
Do you have the NAV system? Any chance this is the NAV DVD system reading the disc?
I'm just trying to locate the general sound location so we can better help you diagnose the source.
deemac Nov 11, 2008 08:23 AM
It is much quieter than the brake charge/discharge noise, it is a continuous but random sounding series of quiet buzzing and clicking. Hard to isolate other than behind the dash, but definitely inside the car. Don't have the NAV system, and the radio/cd is powered off.
Sometimes if I cycle the key off, then on (but not start), the noise stops.
MyPart Nov 11, 2008 08:52 AM
Others may be able to help more but the only thing that comes to my mind is a HCAV selector door motor that's acting up. Does air come out the locations that it is supposed to when you go through the different output options? Does changing those settings or turning off the fan/AC make a difference?
deemac Nov 11, 2008 09:33 AM
It does make the noise regardless if I have the climate control on or off, but I've not tried to change the output selectors yet... I'll check that out and get back to you.
MrT Nov 11, 2008 01:16 PM
If it's any consolation, my '08 FEH is doing the same thing. Sounds to me like a cd transport or hard drive hunting for something. I also do not have the NAV and have noticed it both with and without the radio on. Haven't paid attention to the status on the climate controls when it's happening, but they're generally on auto.
deemac Nov 18, 2008 06:14 AM
So I played with this a bit, and changing the output selectors does not change the noise at all. Now it seems to be getting louder, but that just might be that I'm noticing it more because I'm listening for it...
Off to the dealer I guess... this should be a painful discussion!
08hybridok Feb 19, 2009 12:45 PM
Did you ever figure it out? The wife hears it sometimes, I've only heard it once, but going to get the wrench looked at today so if I cna say fix this ______ too. ;)
deemac Feb 19, 2009 07:07 PM
Did not get it figured out... I did rule out just about anything and everything I could think of... seems to have no link to HVAC, Vent Mixer, CD/Changer, Radio.
Has not gotten better or worse... and I haven't gotten it looked at by the dealer.
Let me know what you find out.
Cheers,
Darren
08hybridok Feb 20, 2009 06:10 AM
I mentioned it when I droped it off, but doubt they will even try to figure it out, I can see "Could not Dupe" on the reciept :rolleyes:
I've only heard it once, maybe twice, but turn everything off, radio, hvac (I don't have nav) and it continues, luckily it only lasts about a min or 2 and the radio has a feature to make it go away (grab vol knob, turn clockwise! :D). I don't think it's the driveshave label mentioned in another thread as we were comming to a stop & it continued even after stopped.
