Brake Wear?
I'm sure this topic has come up before but I couldn't find it with the search engine.
Has anyone surveyed how often brake pads need to be replaced on the FEH? Intuition says that it is less than conventional cars due to the regen-braking, but how much? |
Re: Brake Wear?
Originally Posted by MrCrank
(Post 154129)
Has anyone surveyed how often brake pads need to be replaced on the FEH? Intuition says that it is less than conventional cars due to the regen-braking, but how much? GaryG |
Re: Brake Wear?
Considering how long, or number of drives it takes for all the rust to come off the rotors after I wash mine, I can tell these pads will be lasting longer than the typical car.
Re: Brake Wear?
Unless you are NOT driving your hybrid remotely correctly the brakes will probably last 100,000 miles. Squiky brakes from low use will be the most common issue. I periodically(once or twice a month) drive to about 50 mph PUT IT IN NEUTRAL and brake aggressivily down to stop. This will clean the rust off the rotors.
Here is a list of things you will NOT have to do to maintain your FEH/MMH Replace Alternator Starter Transmission filter |
Re: Brake Wear?
While Ford "expects" the rear to wear faster than the front, all 4 of my pads have the same thickness at 50,000 miles. I am very gentle with them, and do a lot of highway miles. Regen brake does ~90% of my stopping around town.
These pads will last well over 100,000 miles, maybe, the lifetime of the car. ( 250,000 mi ) We should try to find how those FEH taxis did on brake pads. I heard the battery lasted 233,000 to 250,000 miles ) In a meeting with Mary Ann Wright, former directer of Hybrid technologies at Ford, she said to a large group of people that some owners ( IE Gary and Myself ) will never need to change the brake pads. This is not true for everyone one, of course! :shade: |
Re: Brake Wear?
1 Attachment(s)
Originally Posted by gpsman1
(Post 154171)
Here (attached) was the Ford engineering prediction on the brakes as the first FEH's came out.... |
Re: Brake Wear?
My understanding of that PDF is that Ford expects the rear pads to wear at the same rate as a normal vehicle would. If that's the case, then they should last the lifetime of the car since most cars don't user a lot of rear brake to begin with.
I guess we'll just have to wait and see. I also think the cabs would be a good measure of the FEH's worst case scenario of brake wear (among other parts). |
