Re: AWD system on FEH?
Originally Posted by ElectronBob
The diffs are all open. Power to the rear wheels is controlled by a set of clutches in front of the rear diff. The max torque that can be sent to the rear wheels is 50%.
Does the AWD FEH have a system that applies the brake to the spinning wheel (using ABS) to force torque to the other wheel? I know that some AWD vehicles use this system to simulate a limited slip differential using the computer instead of clutches in the diff. |
I've got a followup question on this. With an "open" differential, does that mean that if one wheel on a given axle is losing traction (spinning), then more torque is directed to the spinning wheel instead of the wheel that does have traction?
Well, I guess until now. :cry: |
What I'm referring to is electronic stability control. Its designed to prevent rollovers. I don't think its what you are talking about.
