Electric Vehicle Forums
-   -   Any reason to stay away from 2005 FEH (https://electricvehicleforums.com/forums/ford-escape-hybrid-26/any-reason-stay-away-2005-feh-23807/)
diver110 Feb 3, 2010 08:07 AM
I am looking to buy a used 4x4 FEH to replace my Prius, whose seats I don't find comfortable enough. Often they say to stay away from the first year a car comes out, i.e. 2005 for the FEH. Does that hold, or are 2005's okay? Thanks.
Billyk Feb 3, 2010 02:31 PM
Re: Any reason to stay away from 2005 FEH
Two potential issues with the 2005 Escape Hybrid:
  1. Motor Coolant Electronic Pump (MCEP) have a history of going south around 50,000 miles.
  2. Blend door issue--this is the vent to the hybrid battery location in the rear cargo area. Door doesn't function -open and close-as designed.
You need a Carfax and Service History of the vehicle. I would not purchase an used 05 Escape Hybrid unless the MCEP has been replaced with the newer version. Both repairs could cost you $500.00 each. Search this site for more information.
Other thoughts:
  • Is the vehicle at a Ford dealership? How many miles are on it?
  • The tires on this vehicle came with Continental EcoPlus and it is likely they have been replaced by what? You want low rolling resistance tires on this vehicle.
  • Does the vehicle has the navigational/hybrid radio display? If not, you need to obtain a scanguage II unit to better track what is going on in your vehicle.
  • Mileage-you are not going to obtain the mileage with the 4WD Ford Escape Hybrid that one gets with the Prius.
gpsman1 Feb 3, 2010 03:50 PM
The 2005 has proven to be just as reliable as any other year.
Mine is past 100,000 miles, and many have past 250,000 miles on original equipment ( except tires, etc. ).
