Electric Vehicle Forums
-   -   2009 FEH not going into reverse (https://electricvehicleforums.com/forums/ford-escape-hybrid-26/2009-feh-not-going-into-reverse-32864/)
Wolfy9048 Nov 8, 2021 09:41 AM
I have a 2009 FEH with 160k miles and have owned it the whole time. This scenario happened today:
Pulled out of garage first thing in morning and shut off engine. A minute later put shifter into reverse and engine rev’d to about 2500 rpm’s and vehicle didn’t move. Shut off engine, turned engine back on and reverse then worked with no problems.
It also did the same thing for the first time back in July, 2021.
I checked for codes using the FORScan Lite iPhone app and none were found each time.
I had the transmission fluid changed at 147k miles in March, 2021.
Does this sound like a shifter cable issue or is something else wrong?
econoline Nov 8, 2021 10:40 AM
Re: 2009 FEH not going into reverse
I experienced a similar problem when my OEM hybrid battery was failing on my '07. Reverse is electric only, no direct connection to ICE, so the HV battery must be able to handle the load or ICE will rev but no reverse movement.
What's your battery State of Charge when this occurs?
Wolfy9048 Nov 9, 2021 04:33 PM
econoline,
I checked the average state of charge just now and it was 79.96%, but it has been a couple of days since this incident, but I will check the SOC right away if this happens again.
What percentage SOC would be considered too low?
Wolfy9048 Nov 9, 2021 04:50 PM
econoline,
I don't know what the SOC was at the time of this incident. I checked just now and it was 79.9%. I will certainly check the SOC if this incident happens again.
What would be considered a SOC % that is too low?
econoline Nov 10, 2021 09:48 AM
Your SoC number is too high, should be about 50%, I think it's called "BSOC" in Forscan, be sure that is what you are reading.
AlexK Nov 10, 2021 05:05 PM
Does it go into Drive?
Wolfy9048 Nov 11, 2021 08:30 AM
My BSOC reading is 53%
What is considered a BSOC percentage that is too low?
Wolfy9048 Nov 11, 2021 08:33 AM
AlexK,
Yes it does fine in Drive.
econoline Nov 11, 2021 09:04 AM
Can you recreate the scenario where it won't move in reverse while you monitor the SoC? I would see the rpm's increase while the SoC would rapidly fall below 20%. The electric only reverse pretty quickly discharges a weak battery.
Wolfy9048 Nov 12, 2021 01:11 PM
It has only done it twice in 4 months, but I will leave the readout plug in place and it happens again I can check the BSOC % in real time.
Not sure how intermittent this scenario is, so it could be awhile before it happens again.
