2009 Escape Hybrid engine light
Hi everyone,
When problem first started months ago, the light would come and go. Now it's on pretty much constantly, and this is AFTER the dealer "fixed" it by reprogramming, which is what they told me the problem was. Ironically, the light was on before we were even off their lot. There doesn't seem to be any problem other than the light being on. Still, I tend to think the light being on is a problem in and of itself. Before I waste my time taking it back again, any insights? Thanks and happy holidays to all! |
Re: 2009 Escape Hybrid engine light
Originally Posted by 09escape
(Post 246068)
Hi everyone,
When problem first started months ago, the light would come and go. Now it's on pretty much constantly, and this is AFTER the dealer "fixed" it by reprogramming, which is what they told me the problem was. Ironically, the light was on before we were even off their lot. There doesn't seem to be any problem other than the light being on. Still, I tend to think the light being on is a problem in and of itself. Before I waste my time taking it back again, any insights? Thanks and happy holidays to all! GaryG |
Hi GaryG,
Thanks for your reply. The light comes on when you start the car and stays on until you turn it off. My invoice from dealer states, "reprogram to latest calibration for check engine light," although like I said this didn't fix it. I seem to think I heard somewhere that there was a known issue with a sensor that could cause the engine light, but maybe I'm getting confused in my old age. |
(Post 246072)
Hi GaryG,
Thanks for your reply. The light comes on when you start the car and stays on until you turn it off. My invoice from dealer states, "reprogram to latest calibration for check engine light," although like I said this didn't fix it. I seem to think I heard somewhere that there was a known issue with a sensor that could cause the engine light, but maybe I'm getting confused in my old age. GaryG |
If the light that you are refering to is the wrench light, I may have the fix for you. We had this happen to our 2007 FEH. I did a lot of research and found that many people had the same issue. Some of them were able to repair the proble by replacing the HV Battery Blend Door Actuator, however many of them had the problem reoccur after a short time. I decided to open the Blend Door Actuator to see why they are so intermittent. I found that the electrical connections for the motor were only made by friction pressure. Meaning that the electrical posts on the motor slide into clips. They are not even spring loaded, so after hitting one good bump the connection gets loose. I soldered a wire to the clips and then soldered the other end of the wire to the corresponding post for the motor. This was the end of the wrench for my 2007 FEH. I can't say for sure that this will fix your problem, but it is the way I fixed mine. I hope this helps. Forgot to mention that there is also a filter that can get clogged and cause the wrench, however you would not get the wrench that quickly as you mentioned it came on before you made it out of the parking lot. None the less - You should probably change it if you haven't done it already.
