2008 FEH / MMH Owners in Vegas or Phoenix
I have had an issue where the A/C compressor causes the engine to run about 500 RPM higher than usual. It happens only when the temperature is above 100, and only when the A/C is on.
I was wondering if those of you in the REALLY hot climates could report back this summer and let me know if this behavior is simply normal for the FEH under really hot conditions, or if I should bring my 2008 in for a check up? Thanks. |
Re: 2008 FEH / MMH Owners in Vegas or Phoenix
I am in Vegas and have a new 08 FEH. When I am running home in the afternoon (110ish degrees) and the A/C is on the normal accleration RPM in the car is close to 2200-2400 RPMs (this is versus a 1700 RPM in the morning when it is only 80-85 degrees).
I would think that this is normal. I still can use the ECON on the A/C fine in running home and manage to get about 35ish MPGs when I am driving home in the summer (this is vs. the 41-43 MPG I get running to work). Hope that helps. |
Originally Posted by trekwars2000
(Post 177977)
I would think that this is normal. I still can use the ECON on the A/C fine in running home and manage to get about 35ish MPGs when I am driving home in the summer (this is vs. the 41-43 MPG I get running to work). Hope that helps. I take it you have a normal commute (20 min or more) and an FWD? My commute is 10 minutes and I have an AWD. I don't see those kinds of MPG on my normal driving. I am getting around 30 - 31 on most tanks. |
Originally Posted by stevedebi
(Post 177918)
I was wondering if those of you in the REALLY hot climates could report back this summer and let me know if this behavior is simply normal for the FEH under really hot conditions, or if I should bring my 2008 in for a check up? Thanks. With the compressor running on my 2005, the RPM's are definitely higher, although I haven't noticed if it is even more so for ambient temps >100F. I have not been driving the FEH lately as my other car's A/C is vastly superior. Also the HV battery temp in the FEH is >95F even in the morning, meaning no EV and lousy mileage. Next time I'll try to see if I can detect such behavior, but I think you are probably OK. |
Originally Posted by DesertDog
(Post 178007)
If you are able to go EV, then your HV battery is not overly warm. If the HVB temp gets over 95F, the FEH will force the ICE to run no matter if you have the A/C for the cabin selected or not. Whenever the compressor is on, the battery evaporator gets refrigerant. If the A/C for the cabin is selected, a valve opens to the cabin evaporator. If the battery temp is above about 85F, the A/C will run if the ICE is running, but it will still allow the ICE to shut off normally.
With the compressor running on my 2005, the RPM's are definitely higher, although I haven't noticed if it is even more so for ambient temps >100F. I have not been driving the FEH lately as my other car's A/C is vastly superior. Also the HV battery temp in the FEH is >95F even in the morning, meaning no EV and lousy mileage. Next time I'll try to see if I can detect such behavior, but I think you are probably OK. It is noteworthy that the 2009 has dropped the A/C of the battery pack. |
I've been driving the past few days in 100+ temps, and my 2005 does not exhibit this behavior. RPM increase due to A/C is only 100 or so RPM. I can set cruise @ 45MPH and the RPM will be about 1500. My FE stinks, mostly because the ICE rarely turns off.
(Post 178422)
(Post 178425)
I'm starting to think that they changed the compressor type and/or CPU programming for the 2008 model.
That said, I think I have the ideal conditions to drive the Hybrid. I run 14 miles to work, all surface streets (45 mph), with timed lights - so I know what lights I will hit before I am anywhere near them. |
