2006 FEH transmission noise
My 2006 FEH starts to give noise while driving. It sounds like from transfer case. I Made search and found out bearing failure in transfer case is most common.
Can I change only bearing? Does transmission and transfer case share oil or separated? |
Re: 2006 FEH transmission noise
Originally Posted by jgenb
(Post 256135)
RE: transfer case lube: its not the same weight as the rear differential.
I suppose its lifetime if you keep it less than 100k. But it's definitely not lifetime if you go over 100k. The transaxle uses ATF. Same words on lifetime here also. |
The transfer case, or power take off unit, does not share oil with the transaxle. As I recall it uses 75W-140 gear lube while the rear differential uses 75W-90.
The Transaxle on the other hand uses ATF. |
