08 feh p0128
Hi all,
Ok, son's FEH tripped a code last week. Read it as P0128 which indicates coolant temperature out of range. After some investigation, I purchased a new cylinder head temperature sensor and replaced it. Wiring was good, no corrosion etc. Next day it showed the CEL again and tripped P0128. Most history of this is a sticking thermostat, so I ordered a Ford thermostat and housing. OMG what a PITA to change that. Anyhow, it is all done and hopefully that cures it but I also ordered a temp sender unit listed for the idiot light. I cannot find where this sender is located. Anyone know???? Thanks |
Re: 08 feh p0128
Try to find it: http://www.nicksmustangranch.com/Ser...e%20Manual.htm
Also would be good to read all those sensors with a scan tool and see if they are really broken. |
Re: 08 feh p0128
Originally Posted by ugmw177
(Post 273030)
Hi all,
OMG what a PITA to change that. Anyhow, it is all done and hopefully that cures it but I also ordered a temp sender unit listed for the idiot light. My understanding of the '08 models is that the computer uses the cylinder head temperature reading to infer the engine coolant temperature and there is no separate coolant temperature sending unit (there is also no gauge or traditional dashboard readout for coolant temperature). This was changed somewhat on the '09 models. See the following thread: https://electricvehicleforums.com/fo...ck-open-28850/ Why did you think you needed to buy a new sending unit? Who or what told you to get one for an '08 FEH? |
Re: 08 feh p0128
Thanks guys. Son had the p0128 code..he had it read at oreillys. They advised him it was stuck open thermostat and possibly coolant temp sensor. He ordered parts. When they arrived i went by and picked them up and realized they sold us correct t-stat but sensor they sold us appeared to be for gas escape with coolant temp gauge. I returned both of them and purchased the cylinder head coolant sensor that is correct for the escape hybrid after reading the various service bulletins about the corrosion etc. I replaced it but there was no corrosion at the connector or around the sensor and reset the DTC code. a day or so later CEL returned and i read it as p0128 so ordered a thermostat housing/t-stat from rockauto. Their catalogue also lists a coolant temperature sensor for escape hybrid with idiot light so just in case ordered that too.
Re: 08 feh p0128
(Post 273036)
If I'm wrong someone please let us know. |
Re: 08 feh p0128
I did the repair Friday night and refilled with Zerex g-05; son drove to work yesterday then on a trip about 2 hours away afterwards. He returns tommorow on a 2 hour return trip so will see how it went. Oh and when i was refilling, i purged the system of air and the heat was working well so...
Cars of any type without a temperature gauge are so annoying. |
Re: 08 feh p0128
(Post 273038)
Here's what you can buy for < $40k today and when these cars were in their heyday they were about the same price and - if anything - bigger Nerd Magnets as the ScanGauge depository shows. https://www.truecar.com/best-cars-tr...e-under-40000/ |
Re: 08 feh p0128
The temperature gauge in most cars is a dummy gauge. You can see "too hot" and "too cold" or "just right" assuming its not a light. OBD pid give you a real temperature reading. Real gauges were mostly addon and aftermarket past the 80s. Plus we have 2 separate cooling systems, what should the temperature be for? Mecs? Radiator? Battery?
You don't have per tire pressure but you have per wheel brake pressure... so there is that. Those luxury cars have the sensors and that's nice until they fail and you have all those expensive parts to replace. Mercedes is a big nightmare for that and everyone says don't buy them used. BMW too, along with shoddy engines. If one really wants all that you can get a tablet or android head unit and run a scanning program on it. If both of you have navigation that might be a downgrade but I have no screen.Whole thing is a blank canvas if I want it to be. |
Re: 08 feh p0128
ok, 250 miles later, CEL still off so apparently the new thermostat fixed the heating issue.
Re: 08 feh p0128
(Post 273050)
